Printing out maps, 1 inch = 10 foot?
I've re-created the Temple of Elemental evil level 1 map and I'd like to print it out so that the map squares are 1 inch when printed out. I'm hoping there is a way to battle-map print out this thing and I'll tape the pages together.
Is there a FAQ for such a thing? I
Also, activate tiling and enter the number of pages you need to get your map printed completely.
To create a named view go to
View
- >Windows
->Name Window
You might also have too many tiles for the size of your map. Reduce height and width by one page each and see whether the map still fits.
But those are not the correct print settings, if you want the whole map. Are you sure you set them as you wanted?
Set the layout to "Portrait", scale as 1" paper to 10' drawing, and tile at least 4x4 pages. Do you get a proper print preview then?
When I set the scale factor options to 1'' (paper distance) and to 10'' (Drawing distance) if I tab/select another option the paper distance of 1'' is reset to "0.08333" and the draw distance reset to "10.00000". Does it auto-calculate the settings and that's why it's reset to those values?
If I set scale factor active, print-preview seems to fail as you mentioned. I am trying a print to PDF now to see what happens. When I used fit to page the preview and print works.
Are the lines between pages part of the overlap? The print test I did (using the fit to page) had lines between pages that kinda mixed up the grid. If it's just a artifact of using fit to page print ignore this... assuming the scale factor option print works.
The only question I had left was the bit about the scale factor options changing as I selected options.
