Some questions: Handling CC3
Hi,
greetings from Germany.
I have two questions or two problems.
1. How is it possible to measure a distance in CC3. I want to draw a spaceship, with should be 820 ft long and 180 ft wide.
2. Is it possible to change the scale unit in CC3 to meters?
Thanks for your help.
Bye
Axel
Bye
Axel
Also all of the map templates come in both standard and metric versions. It's easiest to create a map using a metric template. There is a way to convert it, but I normally work with the standard system so I am unfamiliar with the specifics of conversion from within CC3.
If you have previously used another measurement in the map (e.g. drawing your floorplan in feet and now want to use meters), use the "Rescale" option when you change units. If you just want to change the displayed units (e.g. on your overland map you've already drawn stuff with kilometers in mind), leave the "Rescale" option unchecked.
But now i have another question. When i create a cosmographer deckstile, there is the Modern feet bar. Is there something like that vor Meters?
Bye
Axel
