Corrupted file map gone?
I've been working on a new underground city map and was really far along. Something happened and now when I open the file the entire screen is white and nothing is in it, I guess somehow it got corrupted. Is there anyway to recover the file? I have a .jpg image of the city, but not the rest of the surrounding map around it, I had saved a jpg of only the city to print it out.
Thanks
Thanks
Thanks for looking at it. It is now only like 11k and it was a pretty good sized city map, so I'm guessing somehow everything got wiped out. Not sure why. Thanks for your help.
Sorry I can't be of more help.
filename01_001, then save as filename01_002, etc.
'save as' a graphic file from FTPro. load a template in CC3 for an overland map. make a layer called bmp. Insert the bmp into that layer. draw a new map using the bmp as a guide. 'Save as' often throughout the process. Delete the bmp when done.
