Edit Landmass
Is there anyone you can edit some of the main land mass after you created it? I know its just one continuous line to make the body of it. Here is an example. You drew Australia with the landmass tool as one line to create the whole thing. But you decide you don't want to use the north west of it anymore. So you want to delete that region of the landmass. How do you do such if you even can? The reason why I ask this, is because I have some parts of the continent that I really like and has a nice flow, just some other places don't.
If you drew your edit inside the landmass, anything outside it will be removed. If you drew outside the landmass, you will add your edit to it instead.
Been using the program for a little while, but not really attempted anything too complex.
Anyway, coverting a png to a map and traced the outline of the continent (nightmare that was.....)
But, when redrawn it has a couple of places were there are what I can only decribe as spurs. Tried editing the nodes - that just makes a mess and selecting the same editing tool and typing E and attempting to remove the edge doesn't appear to do anything?
Is the outline of the landscape on a different layer to the inner fill, or does it require a different tool to edit?
Any advice would be appreciated.
All the best,
Kevin.
So you can use the Node Delete, click on the spurs, and then adjust it using Node Edit so it looks like you want it to.
These commands can have effects you may not expect. So I suggest save as to a different filename, adding a digit chage to it before each alteration.
Save as filename01, edit, save as filename02, etc. This helps you go gak past the amount undo can handle if you decide the edit is going in a direction you don't like.
However, Edit Node and Delete Node only seemed to allow me to edit one of the issues. The larger one to the right still defies editing - I can't seem to find the nodes that need editing. Anytime I try editing any part, as soon as I right-click it looks like a green explosion.
Is there anyway I can display the Nodes to aid in trouble-shooting?
If you zoom in as close as you can you should be able to pick out the exact kink in the line that sets everything wrong, and either move it or delete it.
Let us know how you get on with it
I would also consider hiding the landmass when you work with this, have only the outline visible. That ensures that your node editing operates on the correct entity, which is otherwise tricky because your landmass and outline actually have their nodes in the exact same locations.
As Monsen points out, the base is where to try the node edit. Very occasionaly I have had to work on other parts.
This is a fractal landmass area, and fractals are a pain.
