Trouble Selecting 1 item
I'm having trouble selecing only 1 item I need when it is on top of another, just as stairs that are in front of both walls and floors. Each time I select the tool to 'Change' or to 'Delete' and then go to click the one I want, it will always keep selecting everything that that item touches.
    Couple of hints:
    - Try to click somewhere on the object where it does not intersect with other objects
    - Remember that you select CC3 entities by clicking at the edge of an entity. Never use the bounding box selection method if you are trying to select a single entity.
    - Use the And/Or/Not modifiers when selecting. See the CC3 manual page 34 and onward for some very helpful selection techniques.
