Perspective Pro Additional Walls Trouble
I am trying to make a tavern/Inn and I am having troubles getting the hang of using certain commands or even trying to figure out how to make something. That one main one being additional walls that are made inside the building. An example of what I am trying to do is found in this one:
http://www.profantasy.com/library/default.asp?Product=PER&PP=9&Start=10&Image=10&OrderBy=
I'm trying to make additional walls that look like a T, but I can't figure out how to get the ones to go 'behind' the main walls instead of sitting on top. The certain spot being the bottom center corner right next to the bar table there. When I make a wall, it sits on top the outer wall. If anyone has any information, I'd appreiacte is VERY much.
I've tried to find video tutorials on this but haven't found out. The booklet helped only so much. So if anyone has any resources they could share, thank you!
I haven't tried this though, so there might be unforeseen consequences. Due to the nature of the perspectives view, the entity order buttons is probably your best bet, and they will still be needed even if you add sheets, especially to manage the entities on the interior sheet.
