Missing Traveller Sector in Cosmographer 3
Been enjoying all of the sector maps in Cos3. Every sector seems to be there except the one that I needed. Ilelish Sector is the one that is missing. Every sector around it is there, but it isn't I am sure that it somehow didn't make it into the installer and is hiding on someone's HD over there at ProFantasy.
If It comes down to it I'll make it myself, but if I don't have to put the effort into that. It gives me more time to make Deckplans and planetary surfaces.
Tasha
Tasha
Tasha
PS thx
Note that you need to use "Decide Settings Myself" and not "Pick a pre-defined template", since this template is only available from the new map wizard.
Thanks everyone!!!
Tasha
This is Joshua Bell, the creator of TravellerMap.com
The map site is generated algorithmically off of sector data. The basis of the "candy" style was a bitmap illustration done by Wayne Peters several years ago. With his permission I adapted the bitmaps into reusable elements, much like the Cosmographer symbols. However, it was done completely independently. The map site does not yet support any custom styles, although it is a feature I would like to enable at some point.
If I had a budget and spent more than an hour a week on the site I could definitely improve the performance. :)
Sorry for dragging this thread off topic, though. Further discussion of the site should probably be over on the blog: travellermap.blogspot.com
Thanks for the update, InexorableTash! Yes, it's bit off topic and I definitly go to the blog
Regards,
Paul
