addlight command
I have been trying to get the addlight command to work and when I get finished all that shows up is a black x where the light has been placed. What am I missing here? I am adding the map I am attempting to use this on for reference.
Now. To get the lights to actually do anything, you need to set up a "Wall Shadow, Point Light Setup" effect on the first sheet that has entities that can block light from your light sources (Usually the "Walls") sheet.
Then, you need a "Wall Shadow, Point Light Finalize" on the last sheet that should be affected by your light source. Anything after this sheet aren't affected by lighting effects.
That did do the trick though, adding those effects to a couple of sheets. I will have to play around with this some more to see what I can get out of it.
Nevermind, found the command.
One way to handle this is to export the map as an image, then use any image viewer to print the image. This is not the best workaround unfortunately, since you then need to handle splitting and correct scaling yourself. Also, once you go beyond a certain resolution, CC3 will need to split the image into parts when rendering it to an image as weel.
