Node Editing
I am trying to change the shape of a landlocked sea. When I choose the same contour and press E, I can make the sea expand, but I can't make it smaller to create a new peninsula. I don't want to use node editing because it will take too long to go to each node. Is there any other option?
Thank you!
  • You could delete and redraw...
    I use the 3 node editing buttons on the left side, unless something is fractalized, it really doesn't take a long time.
    Many of Crestar's surface maps are node edited. I match the different contour fills so their edges all go under the edge of the map border. All done with node editing.
    Node editing does take a bit of getting used to.
