Annual 2007 issue 11 Connecting Symbols issue!
I was just following the pdf and was resizing the 2' template to a 1' template as per the instructions. Everything was fine until it tells me to rename the Sheets that have angles in them Like CA11 Templ vn [5:2]1 to CA11 Templ vn [5:1]1because we cut the 2ft in half to 1ft, but they are already done. so I checked the template by starting it again and it say 5:1 not 5:2 as in the pdf. Is this a problem I should worry about with the template? or should I fix it and how
    Seems like an error with the template. You shouldn't need to worry about this though, it only means that some of the work has already been done for you (However, if you ever need to make 2" wide segment, you will need to fix this template by renaming the sheets appropriately)
