A Couple of Questions
Hi,
I have a couple of quick questions relating to CC3 that I'm hoping you can help me with.
First, is there a way to tell the selected dimensions of an old map. I have one that I want to copy the land mass to put into a different annual style, but I can't remember the dimensions I originally selected so i can use them for the new map.
Second, how do I save a very high detail jpeg. My map is pretty large (same one as above so I can't remember the dimensions!) and every time I try to save it, I can't get enough detail at high zooms to make out text and features. How do I go about saving this at a large enough file size?
Many thanks for all responses,
Mark
Mark
2. After selecting the export filetype, you can click the options button, and set the expost size (in pixels) of the image. The higher the value, the more details, but the max size possible is limited by your installed memory.
Cheers,
Mark
