Cosmographer 3 Satellite Overland Map Question
Hello everyone here at profantasy, I've got a question to ask. I recently purchased Cosmographer 3 (which is absolutely beautiful if I may say so myself) but there is one style that I cannot find. One of the examples on the website is an overland map that has the most awesome satellite crosshairs on it. I was wondering how I could use that same crosshair symbol. I cant find it anywhere. The example says computer overlay style, but i dont see anything like that.
Thanks for your help in advance.
1. Select File -> New
2. In the New Drawing Wizard, select Cosmographer from the Map Type: pull-down menu, check the Decide Settings Myself radio button, then click Next
3. In the Map Style: pull-down menu, select Overland Satellite Map, then click Next.
4. Enter your desired width and height for the map and anything else you might want and click Next.
5. If you want the map background to be the default, leave the box checked and Ocean Dark Sat selected, then click Next.
6. Uncheck Enable Multiple Levels (since you aren't doing a deckplan), then click Finish. CC3 will ask you to select a file name for your map and to save it.
7. Start working on your map!
Yeah, I don't see that map included as an example either, or the symbol. Hopefully Ralf or Simon can post it for us.
http://www.profantasy.com/images/cos3/gallery/gallery17.jpg
However, I do know that I really want that satellite crosshairs thing XD
The crosshair you see in the example is not a symbol itself, because you couldn't adjust a symbol to the map border like that automatically. Instead it is drawn with simple circles and lines. I've attached two drawing tools to draw entites like that on an overland satellite map,as well as the example map. It wasn't included directly, because it is really not a finished map.
