A4
Trying to do a parchment style map in A4-Portrait setting
Whats the best setting t use as every time i pu in the sizes (eh H = 1000, w = 500) it still seems to come out in a rectangle-landscape style
Might be too early in the morning, but any suggestions?
Try the following:
- Create the new map in landscape portrait as normal.
- Thaw and show all layers.
- Right-click the Rotate button and choose "non-visual rotate". Select all, Do it and rotate by 90°, reference point 0,0.
- Zoom extents to get the map back into the middle of the screen.
Now go ahead and draw your map.
*goes to slap self for forgetting about the rotate command*
Edit : This appears to be hapeneing on all maps using the parchment - created a test using another teplate and it worked fine
Edit 2: And as if by magic it seems to be working again. Think i borked a setting along the way somehwere
