Problem with installing CC3 update 9
I have downloaded the update and when I try to install it, I keep receiving this error message
"Cannot start setup- The setup file may be corrupted, or you may have the wrong password.
If you downloaded this file, please download a fresh copy. If the file is password protected, check your password and try again."
Well, I have re-downloaded it twice and still keep getting this message. this is the first time I have had this problem. Any help would be appreciated.
Arrgghh!
Hmmm... It is probably in 'c:\Program Data', a hidden folder.
Anyway, a moot point - JimP reminded me where it should ought to be installed for Win 7 (I knew that all the time! *blush*) - thanks Jim, now my assocs are setup fine!
Did you install everything by right-clicking on the exe installer, then choosing Run as Administrator?
Also, make sure the exe installer is not setup to run in compatibility mode.
