Circle tool drawing floor or walls
I'm having issues with the circle drawing tool. I will select "floor" (DD3 icon, on left by default) then I will right click the draw circle, select the 2 point. When I select the 2 points the circle is drawn and will be a wall/outline, not a solid floor.
At one point I had the opposite problem and it was doing a floor and not a wall that I wanted to draw. Obviously I am doing something wrong but can't figure it out.
If you wish to use the basic circle, you need to set fill styles manually by clicking the Fill Style (FS) indicator, and selecting the desired fill (or extract these properties from an existing entity). Note that the basic circle only draws one entity. It cannot draw both a floor and a wall in the same operation.
The third option is to create a new drawing tool that is a circle. Click "All drawing tools", then "Advanced >>", then select an appropriate drawing tool as a starting point, then click new (this will create a copy of the selected drawing tool), then edit the draw method for your new drawing tool to "ellipse/circle"
