Can I import a map I made with Fractal Mapper 8?
Hi guys, I just bought CC3 and Fractal Terrains Pro and would like to know if I can import the map I made with Fractal Mapper 8 into either of them so I can carry on working on it in CC3 instead?
Thanks for the response Monsen.
But, as Monsen pointed out, it is quite likely faster to just trace over an image in CC3.
I'm going to try turning it off and on again...
Update: Found the patch, that seems to have sorted the crashing.
Firstly in Fractal World explorer increase your map size to 2880 x 1440 (globe view) and then export it as a binary.
Note: I had my map set to "flat with contours" for this but I'm not sure it matters.
Now in Fractal Terrains Pro go through the following steps:
File -> New -> Binary File
Click the choose elevation button and browse to your file in the filename box.
Now the other settings on this screen should be as follows:
Pre-sample info:
4 byte, float selected from the dropdown.
LSB First (Intel) checked.
Line Width: 11520
Header Length: 0
Wrap Horizontally - not checked.
File Data
X Start: 0
Y Start: 0
Width: 2880
Height: 1440
Map Edges
Top:90
Left: -180
Right: 180
Bottom: -90
Missing Data
No Data: -9999
Replace checked
New Value: 0
Hit OK and then Next and then Finish.
Job's done.
Wish I could take credit for this but I got all I needed from this post by Antony:
http://www.cartographersguild.com/showthread.php?1458-Fractal-Terrains-Image-Resolutions
