Feature Request
I realize that I missed the "call for new features", but here goes anyways.
A "Duplicate Sheet" command that would duplicate the selected sheet and place the new copy either just above or just below the selected sheet.
EDIT: to be clear, when I say "duplicate the selected sheet", I mean to create a new blank sheet that has the same sheet effects.
  • I second Lee's suggestion. That would be very, very useful.
    I would also love to see a Purge sheets command. I'm not sure how possible this would be, but something to delete those sheets that only have the "single point place-holder" on them.
    edited July 2010
    We are aware that handling sheet effects can be a bit cumbersome. On our feature wishlist is the ability to copy, save and load sheet effect settings for individual sheets. Would that cover what you are after, Lee?
  • That is definitely a desirable feature in its own right, and using that would be a significant improvement on the current workflow for duplicating sheets (cuts out the need to write down parameters & such). But the workflow would definitely be improved further by having an actual Duplicate Sheet command...whether or not it is worth the dev effort depends on how difficult it would be, and what other feature would be shouldered aside to implement it. As a software developer myself, it *seems* like a feature that should be fairly simple to implement and test, but that's a pretty uninformed conjecture.
