Need tips for this map style...
I'm trying to get better at making maps with CC3/DD3, and I'd like to make maps with the style below:
DMG Map
That is an artwork excerpt from the DMG on WotC site, so there shouldn't be an issue with linking to it. I like how it looks like the floor was just "cut-out" from the parchment. If anyone could give me some tips on how to do this effect with the walls, I'd be grateful!
DMG Map
First I just dropped down a poly, fractal poly, and smooth poly on the Floor sheet & layer, with different fills (moved the fractal to back). Then I grabbed wall tool (closed poly) and used TRACE to make a wall piece that matches all of the floors. (I couldn't figure out how to do TRACE without the wall tool, would love help with that.) I then hid all but the wall layer and put a polygon over the whole map. Did a multipoly with the big block and the traced wall and it cut out the floor area. Show all, add a glow and bevel to the Walls sheet, and this was the final product! I'm very excited about this cutout style!
After that I figured out that I can just make a floor poly that covers the map, then a wall poly to cover the map, then show only the wall layer, and then I just draw a room, multipoly to cut it out, draw a room, multipoly, etc. This saves having to trace your floor if you make it irregular, like a cave, etc.
This still brings me back to my other question--how do you use TRACE when using the drawing tools on the right, instead of the Wall/Room presets? I can't figure that part out.
Well I'll be... I can even make a wall preset that is a closed polygon, too! Nice. I'm going to have to post my finished map with this cut-away style, soon.
