Recreating the Cosmo3 Preview Style Map
Ok as you may have noticed in the Comso 3 topic i've been asking ralf questions in relation to the Traveller Map.. I've been working out bits and pieces so figured I'd show what i've got...
example of what i've got so far.
    Nice work, Rob! Did you switch the Inner and Outer opacity on the realm backgrounds on purpose? It makes the map even more glowy. :)
  • Ralf, Basically i've got it set up like this:
    background - background image taken from one of the annual star system ones..
    Star_Region_Low - Transperiancy - 60%, Blur - 80
    Star_Region_Mid - Trans - 50%, blur - 50
    Star_Region_High - trans - 50, blur - 40
    Star_Nation_Fill - Edge Fade, Inner - width 30, inner 30 outer 100
    Star_Nation_Outline - Glow - outside - 9,199,227 - strength 1 blur 2.000
    Jump Routes - Glow - outside, 172,241,255, str 1, blur 5, Trans 50.
    Symbols - Glow - outside, 255,255,255, str 1, blur 10
    text - nothing turned on
    text_titles - trans 50, glow same as jump routes.
    grid - trans 10.
    mapboarder
    The three star region areas are the blues behind the star nations.
    The fill and outline should be obvious.. as should the rest. I've attached the fcw file.
