Problem with mapping
Hello I just started using CC3 and have run into a strange problem. I am trying to create a contour line to highlight some mountains on the right side of my map but every time I try the line stops at a certain point. No matter what I do the line will not go past it and if i try to start one past it, the line will simply be created at the edge of the "wall". I don't know if I accidentally hit a button or what but this wall is also affecting all of my "default" lines as well. If anyone knows whats going on I would be greatly appreciative.
a) Select the tool button (hammer & pen), click advanced, select the tool, uncheck Restrict to map border or
b) Change the size of your map border (usually green lines on the Map Border Layer)
Glad it got solved.
