CC3: Scrub terrain turning into shadows.
I created a map using CC3 awhile back, and have recently gone back to touch it up and add more shiny bits to it. Unfortunately, when I went to add new landmasses, the Scrub (Foreground) terrain I had used previously (with a light green hue) now only created a large shadow. I have no idea how to reset it to its default state; I've tried changing its color in the Advanced -> Properties menu...and that's actually about the only thing I've been able to figure out to try.
I started a new map, and the Scrub terrain was back to normal. I loaded up the previous one, and it went back to shadow.
I need a place for my orcish vikings to reside...
If you first use info>list on a patch of shrub that does display properly, you can check which fill style it is supposed to use, and then change the drawing tool to match.
