Macro problem
                    Hello,
a few months ago I started to read Joachim de Ravenbel's macro introduction. Now I have to draw the same thing a few times and I thought: Try to write a macro! Hm, of course it doesn't work, but I have no idea why.
Ok, the macro should draw spokes around a point selected by the user. Also the amount and length of the spokes can be entered. Here is the macro:
MACRO SPOKE
SAVESETTINGS
GN varNumber ^DNumber of spokes:
IFERR MacroFail
GV varLength ^DLength of spokes:
IFERR MacroFail
GP varPosition ^DSelect center of spoke:
IFERR MacroFail
GN varAngle 360/varNumber
GN Index 0
:Loop
IFZ Index-varNumber LoopDone
GP varPositionNew ref varPosition <90-(Index*varAngle),varLength
LINE varPosition varPositionNew
GN Index Index+1
Go Loop
:LoopDone
:MacroFail
GETSETTINGS
ENDM
I don't know if CC3 expects ints or floats for point constructs. I've tested both with the same result: the first line will be drawn, then an error is shown.
Could anyone please help and tell me what is wrong?
Thanks in advance
Torsten
MACRO SPOKE
SAVESETTINGS
IFERR MacroFail
IFERR MacroFail
IFERR MacroFail
GN Index 0
:Loop
GN Index Index+1
Go Loop
:LoopDone
:MacroFail
GETSETTINGS
ENDM
Thanks in advance
Torsten
Try the following :
LINE varPosition varPositionNew;
The Line command requires a semicolon to end.
Works fine with it.
JdR
thank you very much for the fast response. It was the missing semicolon, a mistake you just make once. The macro works as it should now.
And thank you again for the great macro introduction tutorials, without them I would have never tried.
Torsten
By the way, macros (and CC3) work fine with floats.
You can freely use
GV varAngle 360/varNumber
instead of GN, especially if you want a number of lines that doesn't divide 360 (ie 7,11,13...)
Note also that the 90-(Index*varAngle) makes the first line always vertical. Should you need it to be horizontal, simply use Index*varAngle.
JdR
