Quick way to put entities on the right sheets?
So, I have a huge .fcw file, a big map made up of six smaller maps.
I inserted the .fcw files into a new, bigger .fcw file and matched up the maps. That worked fine.
Somehow, however, almost all of the entities ended up on the Rivers sheet! Huh? Wha? How'd that happen? Obviously I did something, but I have no idea what.
Is there some way to quickly make all the entities go back to their proper sheets?
Thanks!
Thanks!
But this should not have happened if you had the most recent update installed - before that Clipboard Copy did not respect sheets. So you could install Update 8 (available from the registration page) and redo your copy procedure to fix the problem.
I'll download the update.
D
