Edit entities
I'm new to CC3 and maybe I'm just not getting it. But, I have created a map based on a hand-drawn map from ages ago (traced the scanned image). Now that the basic sheets are done, I want to go back and fill in some spots where my tracing was not as good as it might have been. So, I need to either stretch a 1/2 inch section of the edge of the land mass about 1/4 inch in one place or fill in a gap where the bay needs to be filled in a bit.
However, I can't find any way to click on an edge and drag it to edit it. Nor can I find any way to fill in a space on a sheet and have it not appear that it's a totally separate entity. And in one case I need to create a bit of an indention in a mountain range on the Land Features sheet.
Maybe I should have put this through photoshop or illustrator to get the basic image layers as a single background then added the symbols from CC3?
Look on the left side of CC3 for Node Edit, Insert Node, and Remove Node.
You can use those to move the edges of polygons, such as those you likely used to make the bay.
