Issue with SAVEASM command?
Monsen
Administrator 🖼️ 81 images Cartographer
I am using the SAVEASM command to export images, and I've set the image export setting to "crop". Exporting jpg and png images works nicely, but when I save it to a BMP file, the cropping is incorrect, and it instead generates a file of the exact dimensions configured, instead of cropping the parts outside the actual map area, leading to large white areas on te top/bottom or left/right depending on dimensions. Anyone know if this a a bug with this command? It only happens with .bmp export, .jpg and .png export works nicely with the exact same settings. It also only happens with SAVEASM; EXPORT doesn't have this problem
While on the subject of this command, is it possible to use it to export a rectangular selection, or do you have to use EXPORT to do that? How about the active window? I know WBS can save a rectangular image, but I really need a command I can use in a macro.
Don't have my Tome handy as it is packed away in case we sell the house and move. The Tome has a macro command list in it, but I don't remember if there are details in there or not.
Have you posted to the cc2-l Macro list ?
