Old Paper Style Background
I want to create a map with a background and style that is reminiscent of "classic" pirate maps. (X marks the spot kind of thing).
I tried creating an overland map with the "Coarse Paper Yellow", but this just results in a bunch of red "x"'s on the background.
Does anyone have a tip for doing this? I wanted to use the hand drawn symbols. (Which is further a problem, as I can't even select Coarse Paper Yellow with the Hand Drawn Overland map type).
Any idea how to draw a dotted line (to represent a curving path)?
Any advice?
Any advice?
For the lines, IME, just using one of the dashed line styles (I like ecw-2) with a fractal path work pretty well on hand-drawn maps, if the rest of the map is built from hand-drawn symbols. Use a Solid fill and a nonzero width.
Then you could create your own bitmap fill style in CC3 based on the image.
