WIP The City of Ardenfirth
The largest city I have tried to create. Should serve as a good base for a few campaigns. SS5 Cities of Schley with a hint of Darklands City. Looking at how to add log booms to the wide bay across from Northbridge. Everything I try is just a cluttered mess.
RickoRoyal ScribeMike PattersonLoopysueQuentenRalfWyvernRyan ThomasGlitch
  • Looking at how to add log booms to the wide bay across from Northbridge. Everything I try is just a cluttered mess.
    Have you tried drawing either a simple, quite thin, line, or segments (like logs), to make up a line? Use either black or a suitable log-brown colour. Booms would be typically made up of low-lying, floating obstacles, like logs, rafts, barrels, even ships, linked by lengths of chain under the water, and probably fastened at the shore ends by a boom tower, which would allow the chains to be raised or lowered to prevent or allow access, so you could add some of those floating objects along the line too. You could also have a couple of free-floating patrol boats alongside it for waterborne protection.
    EdE
