FastCad: Menu File not found
So, yeah, haven't fired up CC3 in a while and now when I do I get "menu not found" and - yup - there are no icons or anything anywhere.
How can I restore my menu? What file am I looking for and how can it be recreated? I hope I don't have to reinstall, simply because it was soooooooooooooo difficult to get it installed and working in the first place.
tried doing various forum searches - found nothing
looked up faqs - did not work
tried googling - found nothing
[quote]"Error loading file" means a menu file is missing. In your CC3 folder, you'll find an application called CC3MenuConfig.EXE. This is a program that will run silently and setup the correct menu configuration for the latest version. Run this file and then open CC3 again.[/quote]
Did not work.
Did not work.
Hope that helps! Ralf
Running Update8 did not help, because the mnu file was not there.
just purchased and installed all the annuals and had the same problem …
ran the up-date 25 and every thing is back to normal...
hope you find this if your having the same problem
Q
"Darren"
I reecently bought the Humble Bundle Pack and installed everything.
Now I have a similar Problem: I've installed the programm under another drive, because my C: SSD is nearly full. (Settings: install for all users)
After the installation, I had no problem using the software with the user I installed it with. But when I log in with another user (e.g. my girlfriend) I get the "FastCad: Menu File not found error". Does anybody have a clue, what I can do? I already reinstalled Update 28.
Do her user have access to the location you installed the program to? (i.e. can she browse to that location using windows explorer, there should be a few png files in there, can she view those in an image viewer?)
Assuming she can, on the CC3+ command prompt, try typing
menudm @fcw32.mnu
and hit enter. This should load the default menu file, and CC3+ does remember this between sessions, so if this works, it shouldn't have to be done again.@Monsen And yes her account has full access to the folder. You Workaround seems to work :) thank you very much. No we booth can finally use the tool.
