Cutting down world map leaves Relief/Contours
I have reached the point in my world map where I want to trim it down into sub-maps of kingdoms/countries, and have run into a bit of an issue. The world map was kicked off on FT, brought into CC, and built upon from there. When trying to use the cutting method shown in CA68, I find that everything is trimmed to the inserted rectangle...except the Relief/Contour layer, which retains all elevation and water depth contours, within and beyond the rectangle...for the entire world.
More interesting is that I cannot then even select a spot on any of those contours that will allow me to break or move them.
Thoughts?
