an odd background
I'm playing with Isometic Town from the 2019 Annual, and I've replaced the original green backround with one that's called Heath. It behaves as the transparent background fills and I sometimes need to change the View-Window colour using the View dropdown menu which is why I know that whatever colour is picked it shows through the background.
Why is it set up like this? I had a dark blue background earlier on which really looked wierd.
This bitmap isn't really intended to be used as a main background, rather it is meant to be used with drawing tools to draw patches of heath on top of your terrain background.
One limitation with CC3+ is that fills can't be categorized. So the background fill picker in the new map wizard will simply show all the bitmap fills available in the map, it has no idea which fills are suitable and which are not.
