resizing map
HelenAA
                🖼️ 19 images Mapmaker
            I started a map at 800x800 and after doing battle with the very early symbol and bevel placement, I realised that the map needed to be 1000x800, so I did that only to find that half of the Map Border had stayed behind despite the green line having moved as did the background. Why does this happen?
I checked the layers and the only one that was frozen and hidden is the Template - understandably. While I was checking the layers I noticed in passing that there wasn't a Screen layer but because the template is the Jon Roberts City and thus an old one, I didn't worry too much. Was I right not to worry?
Do you mean the frame around the map area by "Map Border"?
If you do, that's probably because it isn't on one of the layers the Resize command adjusts.
To make it work you could maybe move it to the BACKGROUND or SCREEN layer.
