Fractal Terrains Export to CC3
This is probably a foolish question. My previous version of FT allowed multiple file exports to CC2 so i could drill down from the world map to a sub map, navigate N, S, E and West and then pop back up to the world map.
I no longer appear to be able to do this, i am sure it's me, but i export a world map with one sub layer i can go to the sub layer. The world is 24,000 miles by 12,000 and each sub layer is 3,000 x 2,400 but i cannot go back up neither can i navigate away from the map i am on.
FT3+ doesn't seem radically different as far as multiple file exports to CC3 are concerned, but it isn't working as it used to, is that me?
I think you may be misremembering. I was a bit unsure myself because I don't use this functionality too often, so I installed the older versions and tested, and none of the generated maps had links back up to the parent map.
Could you be confusing it with the html export (from the same dialog)? The HTML export do have the controls you talk about (parent, up/down/left/right)
Thanks for your reply, i wondered if i was misremembering, so i loaded the old version and i could link back up to the parent and navigate around the child maps.
It's not a major concern, but it does seem strange the newest version doesn't let me.
Maybe someone else will pop up with a solution, meantime i shall just embace new practices lol
I don't know why that may be then, but you can at least easily add such links yourself using the Tools -> Hyperlink -> Link with map command. Bit of work if you have many maps, but at least it only needs to be done once per map and saved.
My thoughts exactly. If anything does come of this i will let you know
