Hard edge to bevel
I've got a hard edge to the one edge of a bevel (the one on the left of the map) that I know wasn't there yesterday, and before anyone says 'go back and use that' I can't because I saved over it, not noticing the line till this morning. I've tried fiddling but with no luck. The two bevels have nearly the same settings and sit on different sheets. It's not the sheet settings because I've not touched them since early yesterday, way before I saved over the map. The line looks as though it almost has a drop shadow on it, see below. Any suggestions appreciated.
If you are talking about the darker desert terrain, that's on the BUILDINGS sheet which only has a shadow effect on it.
If I've got the wrong part please say.
Hi Sue, you'd got got the right part but somehow it had moved from the CONTOUR west sheet first to the BUILDINGS sheet in the version I uploaded to the forum to another sheet I'd added to the map. Your comment made me do the MPEDIT command on the contour to put it back where it belonged. How do I keep it there?
What might have happened is that it got accidentally selected when you moved something else to the BUILDINGS sheet. I've done it myself before now.
If you want to make it impossible to select, put it on a layer of it's own and freeze that layer.
