path to linked bitmaps
Hello!
I usually link bitmaps into my CC3 files in the background layer.
Now I have moved the CC3 file around on my harddisk and maybe even the bitmaps location has been changed.
As a consequence the bitmap does not show up in the CC3 drawing any longer.
Is it possible to see the path to the bitmap that is saved in the CC3 file and can it be changed?
Thanx,
André
Thanx,
André
Unfortunately, you cannot change it.
i did the List command on a symbol and all what i found was:
|Symbol Reference: color 15 (white) layer 2 (VEGETATION)
| line style 0 (Solid) fill style 485 (Bosque caduco 2 Bitmap)
| line width 0.00000 tag # 16633 pen :0.000 mm 2nd color 15
| Low extents: 0.00000,0.00000,0.00000
| High extents: 0.00000,0.00000,0.00000
| At: 699.18146,1385.11426,0.00000
| Scale: 22.63167,22.63167,0.00000
| Rotate XY: 0.00000°
And that´s all.
To get the path, open the symbol manager, and do a list on the symbol from there.
But, by the name, this is a symbol from the Cartographer's Annual Issue 28, so just by reinstalling this issue, you should be ok.
