an inverted bevel ???
HelenAA
🖼️ 19 images Mapmaker
Can you do such a thing, using sheet effects? I tried yesterday just putting a minus figure in the Length box (of the basic Bevel) but nothing happened. Just curious.
On the Bevel, Lighted it is possible to make the bevel concave by increasing the value of the Slope Curve.
With a bit of fiddling you can reverse the shading to show the effect of a hollow by unchecking the Global Sun Direction and setting the Azimuth to 180 degrees from the global sun settings.
With the ordinary Bevel, you can't make the curve concave, but you can reverse the shading by checking the Invert Colors box. That would make the polygon appear to be sunken instead of raised.
I've done this by unchecking Global Sun Direction and changing the azimuth 180 degrees. However, I'm going to try LoopySue's process. It seems easier!
Oops! Maybe I should clarify that. When I say changing the value of the Slope Curve makes it concave, that is only a concave slope in the sense of it being steeper at the top and flatter at the bottom. It still has the same 'poking out of the map' result.
