Overlays as guides?
Hi All,
Is it possible to import a map from say a PDF adventure so that it can be used as a guide for re-drawing it using CC3?
Thanks
RobP
Thanks
RobP
I just checked in CC3, no pdf import possible in the insert requestor.
That's just what I need
Thanks
RobP
Open new map that you are going to use.
Sheets -> ADD -> Call it "INSERT" or something along those lines.
Move this sheet just above the Background sheet
Layer -> change to Game Master
Insert -> insert file -> (name of your file to insert)
First click is bottom left hand corner of map (snap on is usually easier)
Second click is top right hand corner.
