How do you keep your $#!^ organized?
So I am doing a bunch of maps. Overland, City and Floorplan.
I keep losing fills. I search through all the different products and I just can't find ones I used recently. Not going to lie it REALLY tries my patience. I go to use fills and the list has virtually nothing. Then I switch and get some more. Then sometimes I even get some red x fills.
How do you keep your stuff organized? I just can't remember which style I hit, let alone the 50 fills I just tried , then switching to a different style and a new selection of fills.
It sounds like you are having an unusual number of problems - especially if you are getting red Xs where you presumably had the fill before.
I add fills from other styles by using Insert file in the Draw menu, picking a map with the fill I want in it, and then pressing ESC just before pasting it. That way I get the fills in that file but not the file itself.
How are you adding them?
I try find the poly in the top bar sometimes.
I also try the edit function and choose the fill drop down
If you are looking for a bitmap fill that you've used before in another map, but which isn't in this current map, use the Insert file option in the Draw menu and pick the older map.
When you get to the point where a paste operation is expected, press ESC instead. Even though the Insert file operation is terminated before the paste CC will already have imported all the bitmap fills from that older file and they will appear in the selection dropdown.
But it sounds like you are talking about fills other than bitmaps. What kind of fills are they?
I've been using a huge assortment to get the effects for my roofs.
I found the red x's are from something a long long time ago.
I'll have to really dig into this try and make my time more efficient.
Maybe if you share a map that has red Xs in it (upload the FCW file here) we might find out what the problem is?
Some general organizational rules to avoid red X'es in the future.
