Lakes?
How can I try to create lakes amidst land masses? of varying colors... Like a large swamp, or a lava lake... I can't even seem to create a normal lake... I've tried contours and when I select water, it always dissappears after the map re-draws
land
rivers
Put the lake on the rivers sheet. Then you will have the lake on top of the land so it can be seen after a redraw.
Hope that helps, Ralf
