Why is Custom PAL being used on other maps?
I modified the PAL to add 3 colors to a map I was making. I then saved it and attached it to the drawing. However, when I open up other maps, it now uses that custom PAL. If I create a map, many of them will use this custom PAL Sometimes it won't, but I think that is because the style has a custom PAL that loads with the style.
I was thinking that the custom PAL was only being loaded because CC3+ was just using the last palette. However, when loading up a style that has a custom PAL and then making a new map, then it still defaults to that custom PAL I created even though I am using a completely different map style.
So, why is it doing this and how do I fix it?
