Finally finished world map
darkveil
Traveler
Just though I would post for comments on my finally finished game world and detail map.
This is a fairly small png so quality may have dropped.
Thanks
Thanks
The Font is "A Charming Font Expanded"
You can download it from here:
http://www.dafont.com/a-charming-font.font
I exported the map as a jpg from CC3 (png export kept failing - the png was ok then corrupted in the bottom half so I had to use jpg which was less clear)
I then upped the resolution to 300dpi in gimp and saved as png
I then imported this into inkscape and did the labelling, compass, scale and border.
I highly recommend inkscape for labelling. The text on path is so easy.
If people are interested I was thinking about doing a quick tutorial on the labelling using inkscape.
Iain
Yes I am aware,but I just didn't get on with the labelling in CC3.
With Inkscape each Object is a separate entity so changing the imported map later is no problem - just a delete and import.
I am going to have another play with labelling within CC3 and that will hopefully either cure me of using another tool to do this or enable me to pinpoint exactly what is more difficult in CC3.
JimP - irfanview?? I have not heard of this?
And that's some beautiful maps there, darkveil. Great work!
