practice dungeon corridor
HelenAA
🖼️ 10 images Surveyor
I'm practicing drawing lines that should have an edge atached, in this case a wall, but mine doesn't and it doesn't. I can't even see the wall when zoomed in. Also I don't understand why there's a short piece of a line that is incredibly narrow.
I watched one of Remy's Live Stream videos on dungeons yesterday but I can't even begin to replicate the walls and rooms.
Not sure why the corner closed off like that, but I moved a single floor node and a single wall node and it's all square now.
The reason you can't see things is a combination of the sheer vastness of the map and the fact that you had no sheet effects turned on - making it really difficult to see that there really are walls and floors involved. I've set this version to have sheet effects on when opened to make things a bit easier.
Thanks Sue i'll look at it a in a moment. But I had got effets on when I uploaded my .fcw file.
The older styles don't have the sheet effects automatically turned on when you open them, but you can change that by checking the little box called "Effects are on when loaded" in the Display speed dialog. It just means that things are immediately clear the moment you open the map. That first screen shot was without effects - either that or so far zoomed out they were invisible. It really is the largest dungeon map I've ever seen.
