I hate learning a new program
Ok while drawing some islands on my map something happened and my main landmass disappeared except for the coast line. is there a way to refill that coast line with landmass color and texture or do I need to redraw the land mass. anyone have any Idea what i might have done wrong??
Steve
  • It might be under the ocean.
    Sheets in CC3 control what shows up on top of what.
    SEA or Contours Sea is where the ocean goes.
    Land or Contrours land is where the land goes.
    Yes, the SEA is at the top of the Sheets list. But that is the way it works in CC3, which uses a CAD engine, not a paint program, for its basic structure.
    You can hide the ocean and move the land masses, islands, to the land sheet. On the left side, next to the pencil, is a Change Properties icon.
    Right click on that icon, select 'Move to Sheet' from the menu that comes up. Then click on the land mass. Right click, and select Do It from the menu. Then select Land sheet from the sheet popup by clicking on the left column. Click Okay.
    The island is now on the land sheet. Hold down the Ctrl key, and tap the r key. ( to refresh the drawing), and it should now look correct.
