Windows go under walls
Nikode
Newcomer
I'm placing windows to my houses walls but the y go under them, how can I make them go normally so that they show up in the wall?
In most styles the windows should cut a hole in the wall. Which style are you using?
A screen shot might help us work out what the problem is here.
Can you find out which sheet and layer the walls and the windows are on using List in the Info menu. It's probably going to be easier to pick just those two things if you hide the FLOORS sheet.
Try moving SYMBOLS WALL below WALLS.
It worked! Thanks.
You're welcome :)
