Delete Duplicate Entities
Hi there! I've somehow managed to create multiple copies of some entities on my map - the compass rose, navigation lines, and two sets of text along a curve.
I need to delete one - and only one - of each of these entities. I've successfully used "List" to get the properties of each, but now I can't figure out how to select and delete only one of the two copies.
One other request. I noticed that in the "List" command the text along a curve were tagged with a group number. Is it possible to select one of the two "groups" for deletion rather than selecting each letter individually?
Thanks!
If you have entities that are completely identical (same position, same properties), you have to select them by entity tag number (scroll down a bit on that page to find the specifics for that particular one).
And yes, the group tags you see in the list output is also an entity tag number, so you can delete a whole group that way. (Individual entities inside a group can only be selected if groups are unlocked, and the group tags can only be selected if groups are locked).
Exactly what I needed - thanks, Monsen!
