change fractal polys to smooth polys
HelenAA
🖼️ 19 images Mapmaker
Is it possible and if yes, what's the simplest way to do it without messing up the map?
I'd like to put roads on my map but am getting lines going to the nearest corner. I think I've overloaded the map with nodes and this is what's causing my problem.
Answers
Fractal to smooth? Yes. I think the command is "STC". At least that is what it says in my command line when I pick Straight to Smooth from the right click menu on my Explode button. (The opposite appears to be "CTS")
I'm not sure what you mean with the roads problem. Have you got SNAP turned on?
