Vintyri, CSUAC, et cetera
Hello,
I have been using CC3+ plus off and on for a few years but I downloaded a map and it has a lot of red "X's" on the map. Looking at the forums it seems I am missing some symbols or objects that are needed. As I searched more I found that there are new versions of all these 3rd party add on's for CC3+. Do I need to start with a clean install?
I am hoping someone says no, but I have resigned myself to the fact I will have to set aside all the time to download and install all of these again. Thanks
Answers
    You're talking about new versions of the 3rd party CC3+ addons, which seems to indicate you already have (some) of them installed? If so, how old are your installs? While there have been some minor updates released, these have been mostly to fix certain issues, the collections haven't changed in a long time.
    If you have one of the very old versions of the CSUAC, then it is probably best to remove that one before installing the updated version. It is not absolutely required, but it saves you from potential confusion in the future. But a clean install shouldn't be required.
    However, you may want to make sure that it is your installation and not the map that is the problem. If it is an older map using the old version of the CSUAC, then maybe you already have the newer version, and reinstalling isn't really going to help you with anything.
    LoopysueJimP
