Fractal Tool in CC3
I'm not sure if I did this but my fractal lines are only appearing as a line with a single angle instead of the regular random line. Is there anyway to reset this? Any help would be appreciated.
Thanks,
Shane
  • There are many ways to restore that.
    a) While using a fractal command, use the right and left arrow keys to lower or modify the depth of the fractal function and the up and down keys to modify the strengh. This will only change the settings for the current entity though.
    b) Click on the fractalise button (usually somewhere middle left, an icon showing a straight line and a fractal line somehow parallel) and edit the settings yourself.
    The depth is a indication of the number of nodes (I think your depth is set to 1). I guess the real number is something like 2^depth.
    The strength is how far the line moves away from the straight one.
    The default values are 30% for strength and 5 for depth I think.
  • Thank you so much. This solved my problem!
    You made my morning =)
    Shane
