Installation Order
Hi, I have read the FAQ about this (many, many times). It says to install independent software after all add-ons. I'm confused about which downloads are considered add-ons and which are considered independent software for the purposes of installation order. The one thing I know for sure is independent software is Fractal Terrains 3. Are any of the rest of them independent software or are they all considered add-ons?
Also can I suggest adding to the FAQ that when installing the latest update you should ignore any warning that you already have a newer version installed (if this is indeed true)? I was conflicted about this and didn't know which way to jump until I saw a Forum post from Sue saying so.
Thanks.
Install order doesn't really matter anymore. The only thing to be aware of is that some add-ons require the latest update, so it is usually smart to do CC3+ -> latest update -> everything else -> latest update again (because it will update some of the files you just installed from the add-ons) [and yea, ignoring the message that you already have a later version.]
OK, thanks.
