CC3, Patch8, & dragging
I like much of what I've encountered in patch 8, however one thing seems to disconcert me after installing patch8. Prior to patch8 when I'm moving or rotating a symbol I am used to using a drag function (where you see an outline of what you're moving or rotating) to guide me in seeing exactly where I'm moving or rotating things to. Now all I seem to get is a thin line, that is especially frustrating in the rotation process in that it doesn't seem to correspond to the direction you actually are rotating to. I was on a time crunch for submitting a map & the air was turning rather blue from me using naughty words in Ancient languages as I tried to get things positioned just right. The 29th Panzer Grenadier division was particularly problematic on the "Black Monday" map.
It is probably some switch somewhere, but I wish I could get the drag figure functioning again. Please, has someone figured out how to turn the function back on again?
Tusen takk or tusen tacos
Sven
Sven
Right Click any of the copy/move/scale buttons, and select "Cursor Options". Then select either "Force dynamic cursor", or "Use bounding box for long redraws" (The last option will switch between dynamic cursor and bounding box automatically depending on the redraw time of the entities you move)
Thanks for trying.
Can you send me a catalog with some of the affected symbols in it to ralf@profantasy.com?
Skal,
Sven
