Accidentally Deleted File
Hi all, new member here. I was taking a crack at designing my first landscape in CC3 and I ended up at some menu I wasn't familiar with and pretty sure I deleted a landscape file I shouldn't have. Any idea if that is fixable or do I need to do a fresh install? I'm trying to avoid the latter as that will also require installing a bunch of other add on software. Picture attached.
251.66 KB
Thanks.
Puddy
  • Have you navigated to the location it says the file should be at and see if it is there? If it is missing, you can probably just run the install again and select repair. That style is one of the basic styles.
    Someone might upload the file on here for you if it is truly missing.
    In the future, you should probably just click to upload the image instead of a file. That way we can see things without having to download the file.
  • Yeah, I looked. it's not there.
    Sorry. New here and not familiar with the functions of the board.
    That's a drawing tool. It probably happened if you investigated the Advanced button on the drawing tool dialog, where it is possible to delete drawing tools.
    It's not advisable for any of us to upload files here unless it happens to be one of the Profantasy Team doing it. If you do as Julian suggested and run the CC3+ installer again it should offer you a repair option. If it doesn't, please contact Tech Support through your account page. They usually react quicky and are very friendly.
